Liked the Neo65 so much, I picked up a second one! ![]()
This one is tri-modeand I went brass instead of copper.
It totally came out better than I imagined!!
Build Summary
- Milky White Neo65 w/Brass Weight
- Tri-mode hotswap PCB
- FR4 Plate
- Neo/QK clip-in stabilizers (sanded & polished) w/Durock gold wires. Lubed with Carbon GS2 (housings) and GS3 (wires)
- SwagKeys x HMX Milky White linear switches (stock)
- Key Kobo Signet keycaps
- Rubrehose 1U and Enter artisans in brass
- Plate and rear case foam
ouuu that’s a neat idea for an enter key novelty
Ciel60:
- Cherry MX Black clear top lubed with Tribosys 3204.
- GMK Dolch R5.
- TX R3 stabs lubed with Tribosys 3204 on housings and Krytox XHT-BDZ on wires.
- FR4 plate.
- 50a oring.
Proof that the classics never go out of fashion. ![]()
I keep coming back to the Bolsalice. I love this thing. Posted this back in December, but no matter what boards I swap to I end up back on this thing.
DSS Lights out on black out. An obvious pairing but I just thought of it. Really enjoying these QK-01 switches. Snappy linears.
I think your “+ =” key is upside down
There is that beautiful DSS profile on a beautiful board.
The damn legends are hard to see! ![]()
At least it’s doing its job LOL!
Silver Neo80 w/copper weight.
Best combo so far:
- switch: Cream Soda
- plate: FR4
- mount: gaskets
- PCB foam: yes
- case foam: no
- PE foam: no
UPDATE: Sounded a bit harsh after awhile. Remedy: Poly-fil.
Switched things up a bit. Split BS on the Ellipse with Gat Yellow Pros 3.0 and Corn caps on the Salvation.
Decided to black out the Fjell (Future Suzuri / boba u4ts). Took out the center post, mounted screws with orings, and relubed a couple switches and now the it finally sounds like the ~$550 keyboard it is. Really digging this build atm
Sound test: https://youtube.com/shorts/lcsXwqvXA0o
Arc60 Safari looks so good. Got Serika on there with some oil kings.
Sound test: https://youtube.com/shorts/f0zxduwILHY
