That’s very nice!
yep. SA Dasher on U-80, ePBT hunter green on a TX-660 and Meridian, GMK Rudy Darkhorse on a green Klippe.
Whats the Ip Man key do?
No idea, but DISS will come in handy for online gaming…
This is the most fun I have had with a keyboard in a long time. The Libra Mini is a treat to build. What a wild board. Stacked (vertical for the most part) acrylic, FIVE PCBs, 40% tented ergo layout and a joystick for the hell of it. It was a ton of fun to build, which is odd because there is no soldering. It’s just a very neat thing to assemble.
Tinkering with the KBD67 v3 this evening. Still has the brass plate and Deep Sea switches. Also in this photo, my favorite key and switch pullers. (Filco’s pack-in and the Wuque titanium puller respectively.)
Some Dusk at dusk.
Okay, TBF it’s way past dusk.
Used a diamond for the FN layer key.
I love the way light hits these.
Tall bois lookin’ good from the back
I like MT3 Dusk with this silver-grey case even more than I thought I would. :3
A classic
Phoenix turned out great. I built this one with the black POM plate, KS-3 gat yellows that have been spring swapped to 69g Sprits and stem swapped to Kailh black long poles, plate foam, case foam, Hub, and a fun little Biine from lividity.
Neat! I had to do a double take. Are the dark caps – yup, they’re transparent. Clean af.
Definitely a Top 5 case for me. I still have mine BNIB, but now I’m motivated to do something about that.
Who would have thought that GMK Red Samuraj would look so good on a keeb!
Right?? I didn’t know that keyset would go so well with that cerakote color.
Melgeek “Plastic”, an unboxing. Kind of.
The packaging was nice.
Keycap puller, USB-C cable, and a 2.4ghz dongle included.
The backside.
The frontside.
I went with the board configured with the Bluetooth and 2.5ghz connections. It’s also got the all important RGB lightshow thing going on and I upfront love that, so no shame in that game.
I actually have the keycaps for this board, I’ve had them for over a year now and they’re neat. Having this board though is a treat. What I didn’t expect was that it sounds really nice to type on. Like it’s not just a gimmick board, it’s an honest contender for a daily driver.
I kind of wish I would have got the 10-key now, but I’m happy with this.
I didn’t know they were translucent keycaps till I got them (traded in the local market). It’s certainly a unique set, haven’t seen this colorway around
Norbaforce Mark III in polycarbonate. I love every angle in this keyboard, the edges are perfectly contoured and the amount of detail in polycarbonate is mind-blowing.
It’s using the stock Topre domes and deskeys #3 silencing rings.
So this is my first mech that I worked on I kept it simple
Its a Womier k87
I lubed the plate mount stabs and did bandaid mod. ( thinking about upgrading to a NK plate mount or Owlabs)
The switches are Novelkey Blueberries
The Caps I found on etsy and the spacebar , WASD and ESC key are traitorskeys novelties .
my Second Build
My most recent attempt at a custom
KBDFans67 Lite R3 in Aluminum Case
TTC Red Flame Linear Switches
Owlabs Owlstabs (housing lubed with 205g0, wire lubed with dielectric grease)
Bredworks Black FR4 plate
GMK Redsuns Keycaps
Traitors Space bar and WASD
and Hotkeysproject Artisan .
Like I said pretty new to the mech keyboard world but so far having a blast.
