I gotta ask,
1u WIN key… Code vs Super, which do you prefer?
Super is pretty super
Corne/CRKBD with hotswap MX, Elite C on the left and Pro micro on the right. Using NK_ Blueberry switches for the main alphas and Hako True for the thumbs and modifiers. Frosted Acrylic from keyhive, XDA keycaps from Amazon with DSA homing keys. The mat is a gaming mat from Infinite Black that they sadly don’t sell anymore. I finished this bad boy last week and love typing on it. I look at my Hotdox and I’m shocked in a year I’ve reduced my key usage so drastically but so easily.
I’ve since added the second OLED, but I’m having issues getting it to flash on that side. I can get the left side to work flawlessly, but anything that does that, the right side of the keyboard does not work at all… like the keys don’t respond. I had to move on to other things so I’ll be digging into QMK’s dark corners to try and find a solution. I want to try to get things like long holding a key for shift and combo keys, but those require custom firmware, and that’s where the process fails. Gotta read more and learn before I leap into the deep I guess.
Also ya’ll take way nicer photos than I do lol.
Tsangan, split backspace, stepped caps?
Ah, I see you’re a man of culture as well.
best layout
GMK Jamón on the silver Norbatouch (pi edition).
This is probably the hardest set I own to color correct for, simply due to the intense amount of red thats used…
looks pretty close to IRL, must help to live in a pink void
Haha
So very true, I do like a bit of pink in the background… I really need to get some more colored paper or something else to shoot on.
First build from a while ago:
TADA68 with black metal case
Kailh Pro Purple (unlubed) switches
Some Aliexpress 9009 DSA keycap set
TADA68 is such a classic. Looking good!
I appreciate the consistent background, especially for sets I don’t own, its good to have a frame of reference! (I also just like pink)
I think Tai-Hao sells a Jukebox keyset in their cubic profile.
Hobby might be getting a bit out of hand. Started with the anne pro 2 on the top left that was moded with novel key creams (desoldering and soldering was not as hard as i thought it would be … though i probably did an ugly job), new keycaps, lubed stabs, and an aluminum case. Then got the hhkb on the top right … then a melgeek dusk on the bottom left (only mod here is me replacing the gateron yellows with gazzew boba u4s) … and last is my own custom creation that I posted about here (What is on your desk today? - #2243 by xli92149).
though now, i’m waiting on a soya rama works kara … and am pretty sure that i’ll buy into norbauer’s heavy grail. not sure where this will end …
Does that Mojo60 support QMK? How is it customized?
qmk support is spotty, they have their own proprietary software, was easy to reconfigure to my needs and havent had any issues
and re customizations in terms of the key commands:
caps lock = cntrl
win and alt positions on l switched
shift turned into fn key
and then some changes made to the second layer which i’ve made accessible via the keycap that is in the right-alt position
making the changes took a couple of minutes and then simply uninstalled the software (Software &Firmware Download -MelGeek)
It only seems appropriate that you now have another EXENT because it is the apotheosis of bezel bois.
Do you own a single dainty keeb or can they all serve as a melee weapons in a pinch?
I feel like there should be a mod for [ given popular hero shooter or RPG ] that replaces all the weapons with chonky keebs. The strength requirements for an aluminum Melody96 are pretty high but you can one-shot lower level mobs with it.
