I guess this also fits here?
Noisy recording, and a little dramatic compared to how it sounds IRL, but the general vibe of heavy, rumbly bottom-outs is correct. Sound stuff is not something I’ve been great at. ![]()
The Portico I built over the weekend; mostly about the stab test at the end. (Designer Studio Adaptive stabilizers)
That sounds great. Seriously impressive.
A couple recent videos:
Salvation + Monokai Material + HMX Swift + FR4 plate + TX AP stabs
Cypher r4 + Wasabi v2 + HMX Su Pink + Alu plate + TX AP stabs
POM Sirius60 + Striker 2 + Gat Smoothies + 3d printed PLA plate + TX AP stabs
Viktus Sinne w/ 3d printed weights + Oblivion + HMX Canglan V2 + PC plate + TX AP stabs
That clack is music to my ears
The Mode Envoy with BSUN Pine tactiles that I re-built the other day.
Very nice, sounds like you got the Envoy tuned really well!
Put new stabs in my old CTRL today:
This time I gave the Durock V3 plate-mount stabilizers a try
They aren’t perfect, and I don’t think they are quite as good as the screw-in Adaptive ones from Designer Studio, but they are easily the best clip-in (edit: that is, plate mount) stabs I’ve ever used.
Speaking of clip, I did have to clip the bottom to get the sound I wanted - these ones have a single bar-shaped foot protruding from the middle of the bottom of the stem which does make a nice clean clack, but I want quiet for this build. Thankfully, the bar is easy to remove with flush cutters - no more clack!
While these work on the same principle as the Adaptive stabs, the stems aren’t the same, and don’t have the same level of tightness. Most of these were rattle-free with just a thin coat of 205 on everything, but a couple still had some rattle, which was mostly fixable with a little extra grease. I imagine someone good with stabs could get rid of it easily.
This is an unforgiving chassis with its integrated aluminum plate and clip-in-only compatibility, and still I don’t think I’ve ever been this happy with how my CTRL sounds and feels. I’m gonna be using it a lot more now. ![]()
…Wherein my Box Navies and I troll 99% of people in the hobby, but I unironically love these heavy clicky monsters.
As expected, this little solenoid running on 3.3v and entombed in PLA plastic doesn’t blow anybody’s socks off, but it makes me smile and occasionally giggle like a child, and after your first couple of boards, that’s what I’m here for. If I ever have to crack this board open to solder anything, I’ll move it to the 5v rail and see if it gets any more oomph.
loved the vid
So good
Recorded with my MacBook: W1-AT 1.2mm PCB, MX2A Browns (L/F), GMK Nuclear Data.
Very nice man! Got that classic lubed Cherry sound & the board is complimenting it IMO! You running your W1 plateless by any chance? Also I gotta say I’ve been falling love with the sound & feel of Cherry switches again myself. I haven’t really used any in my builds for awhile since we got flooded with a bunch of really good linears from other manus the past few years. However with the MX2A retooling of Cherry’s equipment I got curious how much they improved so I been grabbing them up here & there while the molds are still fresh. I recently built my FLX Virgo with spring swapped & lubed MX Oranges (MX2A don’t need filmed IMO, they really tightened up the housing fitment a ton finally) & have been loving it! Anyways awesome build & sounds great man!
Yes it’s a plateless build. Thanks! I really enjoy Cherry switches. A lot of linears are perfectly smooth, a tad too smooth for me. I need some feedback when pressing keys, either if it is a felt or audible scratch. Enjoy your MX Oranges ![]()
And to keep it going, this is my Keebwerk NASU with an alu plate, L/F Cherry New Nixies and GMK Hi!Viz. Recorded with my MacBook as well.
And the last sound test worthy one: my custom BOLT with a layered stainless steel case. Kailh Box Navies in a 1.5kg heavy case and MT3 Dev/TTY keycaps. Plate is alu.
Very well done. And just in time for my Transition Lite TKL, which is arriving soon.
I am considering MX2A Browns for it. Should be flexy, using a 1.2mm PCB. So it might be a little like yours.
Could you tell me how you lubed those Browns? Which springs were swapped?
Sounds like a plan! ![]()
I lubed them just slightly with Tribosys 3204 and tried to avoid the stem legs. Swapped the springs for 67.5g 22mm triple-stage springs.
Hope this helps!
