I use a wet paper towel and one of these:
How’s that desolder gun? I just picked one up a month ago but haven’t used it yet.
Heaven. It is heaven.
I really like your light blue QXP better than the navy version that I have. You can really see the curves and low lip in the lighter color.
Beggars can’t be choosers I guess I was happy to find this one for a good price.
Rama U80-A (Moon)
- Boba U4’s w/ 65g TX short springs
- ePBT Spectrum
GMK Nautilus R2 just came in so I think this guy might get an update, once I finish lubing some U4T’s.
Space65 CyberVoyager (White/Gold)
- H1’s w/ 67g TX short springs, 205g0
- KAT Eternal
Share the deets!
Dammit! Clean af my friend. That’s my steezo right there.
Scored some SA-P Snow Cap blanks from r/mm to go with my original set. I was pumped to get some blanks, because it makes the set so much more flexible for me now
Got my Devastating TKL in today & built it up with JWK Lavenders (spring swapped to 50g TX long springs lubed with 105, then housings & stems lubed with GS2) & smokey V1 Durock stabs (lubed with 205g0 on the housings & stems, XHT-BDZ on the wires). It only came with an FR4 plate, but it really suits the build well IMO. I burger mounted it & sounds very good that way. Zero hollowness to this case!
Managed to snag a unikorn recently. Built with mx hyperglides w/205g0 and 65gm TX springs w/105 on aluminum plate.
I kinda understand the hype now. The sound is easily the best 60 i’ve typed on by a mile but the typing feel is the real winner. So balanced and satisfying kinda hard to describe. Definitely as pseudoendgame as it gets.
Unikorn definitely one of those super amazing boards you can’t believe is super amazing until you try it! That’s a pretty fun build you have going on!
Typing test? :3
Love the finish.
Yeah, I got this from a friend for a good price, otherwise I wouldn’t have been able to get one either! Honestly didn’t even notice yours was a different color, I just assumed it was lighting. Still looks awesome though!
Don’t have any decent equipment to do it right.
Andy did it a similar build that sounds pretty similar to mine. Twitch
On my desk for a brief while… unfortunately Kitty KAT has been plagued by a shrinking 7u spacebar issue, so while it was so great to look at I moved the caps over to the Vulcan maja afterwards…
