Nice but yes the contrast between alphas and mods is a little bit to high.
edit: my bad, didn’t read properly.
shame, especially with the delays (soon forgotten), but it is what it is
Btw, the set is really clean and beautiful !
Lovely! Thank you for sharing. I had a feeling the way to go would be Kailh hotswap sockets.
One week into using an ortholinear layout. Loving it so far. Box Jades, brass plate, and a mix of spare keycaps.
I love the handwiring artwork
Decided to pull this beast out today since it’s been awhile since I’ve used it. Almost forgot how nice & soft (not flexy) OG Cherry boards can be. The plastic case & plateless design definitely have unique feel compared to enthusiast boards we are mostly used to. I do put a sheet of shelf liner under t he PCB of all my Cherry boards as it makes them sound a ton better IMO, but has very little effect on typing feel. Maybe makes it a tiny bit softer than stock.
I’m so digging the space cadet vibes. Sweet.
Killer wiring - would be right at home on reddit’s “cable porn” subforum dedicated to aesthetically pleasing wiring and cable arrangements.
EMT Linear Switch
Linear Switch
63.5g Non-Gold-Plated Springs
Same Spring Material as the SP Spring
POM Stem Material
POM Top Housing Material
POM Bottom Housing Material
5 Pins
No Factory Lubing
4.00mm Travel
Made by YOK
Designed by Skrgugu -
POM Glacier Panda
Linear Switch
POM Housing Material (Top & Bottom)
POM V2 Linear Stem Material
67g Spring Weight
Original BSUN Panda Housing
5 Pins
PCB Mounted
Unlubed
Designed by Alphakeys
Manufactured by BSUN
Is the Mesa the one with the low front height? This is one that I regret missing out on. Looks great.
It is! Still have been going back to it after the mandatory new-build-gotta-use phase of newer boards
¿What keycaps are those?
Now that is what I call a real custom keyboard.
So nice!
. GMK Rouge + colour sample + Esclab Series 00.
