Off topic but still cool:
Turned my C64 mini into this little thing that I can mount in a 3.5 inch floppy bay.
Amazing!
Love it. Love your mod. Love the NES on the ground. Love your wall decoration. Love your toe
Thanks. I try
Leading Edge Blue Alps snuck into frame too. Nice find.
What!?!
So just when you think you’ve bottomed out, there’s still a bump left to go. Nice. Could you have the bump occur on the upstroke? Kind of like haptic feedback on a PlayStation controller.
First time desoldering (a whole board)
Took a couple switches to get used to it, but I think I have it now. I’m starting on one side of the pad, then moving the iron to the other side, then gently pushing against the pin until I see it moving—at which point—fwoop!—I solder sucker it up.
This is the correct face for “desoldering a whole board”
Bahaha, wish me fortitude pleasee
Maybe. 1mm is rather a small space though. I think a sloped ledge at the end may be more realistic than a bump with each keystroke ending on the ledge.
Results from the prototype:
Know any dope mods for a Logiteck MX Master?
I just have to ask because curiosity;
Do people who have mice with holes have issues with sweat and crud accumulating at the vertices of those hexagons?
This is my 2nd hole mouse and I haven’t had any issues, but I also don’t eat any where near my PC and I don’t like the way my hands feel if they’re a bit oily so I wash my hands pretty often…
No keyboards today, but giving my 1973 mini Marantz some much needed care. New bulbs, fixing a solder joint, cleaning etc. Will post an update when I’m finished ![]()
Edit: posted some pics over in the audio thread: Audiophiles, audio & stuff thread - #79 by M_er_sun
I clean out the hexes with qtips when they get a bit dirty. stays pretty clean.
A curated selection of tactiles for a new build client; 8 stock and 8 frankens.
Bluish White
Boba U4 62g
Boba U4TB 62g
Dragonfruit
Ink Kangaroo
Polia
Taro Ball
T1 (Dark Amber)
Polia stem in Boba housing
Polia stem in Kangaroo housing
Bluish stem in Bobagum housing
Bluish stem in Boba U4 housing
Bluish stem in Ink Black housing
Dragonfruit stem in Bluish White housing
Dragonfruit stem in U4TB housing
T1 stem in Queen housing
Springs chosen to compliment tactile relationship of stems and leaves; some from donor switches, some from elsewhere.
One of these will be going into a modded Miya Pro, when the time comes - set to adorn the desk of a newly-minted punk-musician-turned-lawyer.
What kind of video card can you run in that?
