Just found out VIA now supports Planck. Looks like all the revs and versions by OLKB. I flashed my rev4 and it seems to be working just fine. Now I just need 47 SKCM Oranges.
Is that the latest release? A few weeks ago it showed up in the repo, but wasn’t in the release.
Edit: Release is 1.3.1 which does not seem to support the Planck Rev 6.1. All I get is a searching for devices.
The SKCM Creams on my AEKII are waiting to be desoldered
Don’t know. I went to “Supported Keyboards” page on caniusevia.com site and saw OLKB Planck so checked the Firmware page on the site and downloaded from there. The only thing I can confirm is it’s working for rev4.
UPDATE: Oh, now I get what may have been referring to VIA when you mentioned version 1.3.1. Yes, I’m using VIA version 1.3.1 on macOS. Don’t know what version the Planck firmware is.
After a bit of a hiatus, reopened the keyboard workbench with a warm-up. I had a bunch of desoldered 3-pin MX Blacks from my 980M, so I oiled the springs (and left the switches otherwise unlubed and unfilmed) and dropped them into my only 3-pin board.
And capped it off with the Susuwatari set that came with the Alt. (It’s my favorite MT3 set despite my predilection for lighter-hued keycap sets.)
And I reconfirmed that I, indeed, am indifferent to 65%, and am firmly in the 60/HHKB camp at the moment.
Lovely combo! I came to the same realization recently after building my KBD67 Lite. I love the board but the layout isn’t for me. I remapped the pipe key to backspace and then sadly realized that it probably wasn’t meant to be.
Paradoxically, I like normal backspace on ≥ TKL, and the shift/arrow cluster on a 65% is similar to the FC980, but for some reason, 65% just ain’t my jam.
haha.
In theory, I’m building a KBO-5000. In practice, I’m triggering the part of me that goes nuts in a cluttered work environment.
Also, pro tip* for y’all out there. Boba U4 RGB’s don’t have a pass through for a through-hole LED. I mean I knew that before hand, but I cleverly forgot until after I’d soldered them all in.
* I am not a pro.
Indeed they don’t - though if you don’t mind to trade a little wobble-tolerance for compatibility, you can swap the tops for Outemu ones. Gazzew sells them as “clear slot tops” - 3DKeebs stocks them as well.
Naw it’s fine. I decided to tell folks that I intentionally only put back lighting on the main keys and escape. Because I like the look. Then I’ll convince myself and the circle will be complete.
Lubing and filming 8008 inks while watching Twitch. Wish I could see close up without glasses. Sucks to get older sometimes.
I second your sentiment. I totally resorted to using these as I can more clearly see what I’m doing when applying lube to the brush:
Those look very handy!
I have my first pair of progressive lens glasses on the way - definitely feel you on the getting old sucks bit after that eye doctor visit!
Tangerines are quite striking. I have several hundred switches to lube and film for upcoming builds, so I’m experimenting with small batches per day instead of a hundred at a time. #sanity
Turns out, there’s always an opportunity to RTFM and learn
After actually flashing the VIA firmware to the Planck first it now shows up in the VIA.app.
Sorry about that. By “VIA now supports Planck”, I meant there are now VIA firmware for Planck.
Was thinking about getting a Norbaforce, but decided to do a simple cable mod instead. Used that money to buy another uke.
Well color me interested. I’d love more details. I’ve wanted to do a removable cable mod for my 87u for a while now.
Just using a Norbaforce breakout kit and a mini USB extension cable. Don’t have the proper tools to drill into the case and such but it works for now.
